Ett svenskt cannabisforum Forums Coffeeshopen Sjukstugan White Flys – Hur få bort? KORR: Trips
  • White Flys – Hur få bort? KORR: Trips
    Posted by word on 2009-03-04 at 19:05
    Detta har jag av någon händelse fått:
    White flys:
    They look just like tiny months, and lay eggs on leaves and or top of the soil. They are a pest in big numbers and are not very hard to get rid of, they can cause damage by sucking sap from the plants. Here are some ways NOT to get them: Do not overwater your potted plants. Allow the soil to dry between waterings and provide good drainage. Another one is to put sticky traps up when you think you may have them, that way when they get stuck you can identify them.
    if you already have white flys, you can use insecticidal soap, this will help stop them from flying so it wont infect other plants.
    It also stops them from laying new eggs. If you use the soap reapply weekly.
    If insecticidal soap does not work too well, there is some other options that are stronger called PERMETHRIN dust, Which can be used during flowering and is safe on ediable plants.
    Here are some other good things to use to rid of white flys: PERMETHRIN and biffen (both are safe to use on ediable plants),
    Spreader sticker ( hich allows to apply the spray to a wider area)
    Nylar ( works well for inhibiting there growth and development)ORTHENE FOGGERS works well for a small area and are safe on the plants.Other poducts you can try are:
    Chemicals
    Hot Pepper Wax,Safer Yard & Garden Insecticide (which can be used right to the day of harvest),GNATROL( used in hydro in the water as well as soil),Doc’s Neem Pest Soap,Safer Sticky Stakes,TR-11000 Pyrethrum
    Det är små flugor som flyger och larver på bladen, antar och hoppas att det är samma :D
    Tittat på Nordic och sett deras skadedjursbekämpnings, eller Radar? Och hur mycket sprutar man, Heltäckande över varje planta, Rikligt?
    I kombination med lite Tobaco Juice?
    Tacksam för svar!
    replied 13 years, 7 months ago 2 Members · 4 Replies
  • 4 Replies
  • z0rdim
    2009-03-04 at 22:14
    Vattna underifrån och kör behandling med såpsprit på bladens undersidor en gång i veckan. Går också att bekämpa med “Encarsia formosa” som är en typ av parasitstekel som lägger ägg i vita flygare (går att köpa från tex http://www.lindesro.se, rätt stor mängd med 1500 kan tänkas, har dock ingen koll på faktiska användningen av predatorer).
  • word
    2009-03-05 at 22:20
    Kollade med microskop och såg att det var trips, Det och dom svarta/mörka fläckarna bekräftade det.
    Köpte Res-Cue eller nått på Plantagen och tömde på dom, Hoppas det!
  • z0rdim
    2009-03-05 at 22:52
    såpsprit fungerar även på trips (och spin, för spin är det dock behandling var tredje dag, pga att de kläcks i den intervallen) (vilken intervall som gäller för trips vet jag ej)
  • word
    2009-03-06 at 07:19
    Ska upprepa behandlingen av Res-Cue om 7 dagar, Antar att sprayen är något sorts långverkande gift, som inte är verksamt efter 7 dagar :S
    Tripsägg kan ta upp till 16 dagar innan dom kläcks (tack Wiki!), Kan tänka mig att det är det som är det jobbiga med att bli av med dom, Om inte insekts-sprayen tar kol på äggen med..
