• The Global Cannabis Commission Report
    Posted by reaper on 2009-10-20 at 20:41
    Fick fatt i denna rapport från en norsk tidning (indirekt via ActNow) som skrev om fördelarna med en legalisering av cannabis.
    Kan verkligen rekommendera alla att läsa denna, då den sätter in riskerna i sitt sammanhang och jämför med andra substanser (lagliga som olagliga).
    Den är på bra många sidor, men klart läsvärd. Tror dock inte att en riksdagsledamot hade viljat läsa den om dom planerar att hålla fast vid en repressiv politik (som absolut inte har någon inverkan på bruket)!
    Första rapport jag läst som gett handfasta råd på hur man minimerar sina egna risker om man ändå väljer att använda cannabis:
    • They should not drive when intoxicated (that is within several hours of smoking a ‘joint’), and should especially avoid driving after combining alcohol and cannabis use, because their impairments may be additive.
    • They could eliminate the respiratory risks of cannabis use by changing from smoking to the oral route. If they persist in smoking cannabis, they should not use the deep inhalation and breath-holding technique which greatly increases the delivery and retention of particulate matter and tar. It is possible to minimise the harms of smoking by using a vapouriser.
    • Cannabis smokers who do not otherwise use tobacco should avoid mixing tobacco with cannabis when smoking a ‘joint’, if they wish to avoid developing nicotine dependence and the substantial and well-established adverse health effects of tobacco smoking.
    • Cannabis users could minimise the risks of dependence by reducing their frequency of use to weekly or less often, and by avoiding daily use which carries the highest risk of dependence.
    • Evidence is emerging that cannabis with high THC and low CBD levels may carry extra risk of psychological harms. High THC and low CBD levels are most commonly found in the genetically-modified and hydroponically- grown forms of cannabis (‘skunk’).
    • Pregnant women should not smoke cannabis to avoid reduced birth weight.
    • There is a convergence of evidence suggesting that initiating cannabis consumption before the age of 17 significantly increases the likelihood of experiencing adverse effects, both personal and social. Children should
    therefore be advised of these risks.
    Där finns även mycket diskussioner om olika cannabispolicy’s som råder i världen, och vad dom innebär för brukaren (med familj) och för samhället. Efter att ha läst denna så förstår man varför fler och fler länder går över till mindre repressiv politik!
    (Kanske något att skicka till riksdagsledamöterna i hopp om att någon vill ta till sig av fakta?)
    http://www.beckleyfoundation.org/pdf/BF_Cannabis_Commission_Report.pdf
    replied 13 years ago 0 Member · 0 Replies
  • 0 Replies
