Ett svenskt cannabisforum Forums Universitetet – Cannabisodling U| Odlingsplatsen – design & konstruktion Negativa joner, jonisatorer förbättrar din hälsa.
  • Negativa joner, jonisatorer förbättrar din hälsa.
    Posted by HydraMan on 2003-11-29 at 18:53
    En mkt informativ artikel som kommer in på kärnan i ämnet.
    Ex. råttor fick stressreaktion av för mkt positiva joner, negativa däremot förbättrar hälsa.Samma gäller för växter.
    Som bekant brukas jon och ozon generatorer av trädgårds intresserade för att rengöra luften i sina växthus.
    Tillförlitligheten i denna källa har jag ingen aning om, men en mkt genomarbetad artikel med referenser som verkar solida, god läsning allesammen.
    http://www.vrp.com/articles/945.asp
    Later, researchers measured the impact of atmospheric electricity on human subjects by monitoring daily changes in urine excretion of neurohormones in samples gathered from 1,000 volunteers exposed to positive ions generated 1 to 2 days prior to the arrival of a storm front. By measuring the changing levels of neurohormones in the 24-hour urinary output of the subjects during normal and weather-stress days, the researchers compiled a profile of changes in levels of serotonin, 5-HIAA (5-hydroxyindole acetic acid, a serotonin metabolite), adrenaline, noradrenaline, histamine and thyroxine. The researchers found that “the electrical charges (positive ionization) engendered by every incoming weather front produce a release of serotonin.”20 They further identified three classes of weather sensitivity reactions: 1. serotonin hyperproduction causing a typical irritation syndrome: 2. adrenal deficiency producing a typical exhaustion syndrome; 3. hyperthyroidism with subclinical “apathetic” thyroid symptoms. Noting that these conditions occur during annual wind storms (Sirocco, Sharav and Santa Ana winds), the authors stated that the effects, “which are mainly due to positive ionization of the air,” could be ” prevented by negative ionizing apparatuses or specific drug treatment.”21
    Another clue to the role of negative ions in health comes from Russian research conducted at the Institute of Theoretical and Experimental Biophysics of the Russian Academy of Sciences, in Pushchino, Russia. Researchers found that exposure to negative ions increased levels of the protective antioxidant enzyme superoxide dismutase (SOD) in mammalian erythrocytes. The researchers also discovered minute amounts of H2O2 (hydrogen peroxide), writing, “The primary physiochemical mechanism of beneficial biological action of negative air ions is suggested to be related to the stimulation of superoxide dismutase activity by micromolar concentrations of H2O2 (hydrogen peroxide).”26
    Där har vi peroxiden igen. Vi kan altså med negativa joner stimulera våra immunsystem. Primärt då genom bildning av små mängder H202(väteperoxid) som skapas av de negativa jonerna.
    Hmm, ännu mer stöd för att peroxid är en del av naturen, vissa har ett motstånd mot peroxid då de ser det som en stark kemikalie.
    Rätt koncentration löser problemen.
    Den rengörande kraften av ozon-joner-peroxid används i allt större utsträckning. Redan ett flertal år sedan visade Japanerna upp en tvättmaskin som rengjorde med ultraljud och Ozon, inge tvål där inte :D
    replied 18 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
    2003-12-08 at 01:57
    Det stämmer.
    Men är ozongenerator och jonsator samma sak? Jag har inte fått riktigt kläm på det där.
    Här finns mer intressanta länkar om jonisering:
    http://www.innipowerflex.com/energiluft.htm
  • HydraMan
    2003-12-08 at 08:19
    Tja, i de flesta Ozon generatorer tillverkas det både O3 och joner.
    Det beror på spänning(antal Volt), 6-10`000V ger mer ozon, runt 3-4000V får man mest negativa joner men även små mängder ozon.
    Beror såklart på konstruktionen ocskå, jag menar galler-glas-galler metoden eller liknande.
    2003-12-09 at 15:48
    Kanske därför som inte jonisatorer kommit ut på marknaden i någon större omfattning. Även att de släpper ytterst lite ozon kan kanske upplevas som störande.
    Såg för minst 10 år sedan ett program som visade hur extremt effektiva de är som askkoppar osv (tror det var Svenska Fläkt som tilllverkat något?).
    Clas Ohlsson och Rusta har haft jonisatorer för några hundra, men de har ganska så kvickt dragit in dem från sortimentet. Beror det kanske på att det är svårt att tillverka sådana med bra kvalitet?
    2003-12-11 at 13:41
    Bara att jämföra med syre, livsviktigt,, men i ren form rejält skadligt.
    Läste i nån odlingsguide att http://www.kjelloco.se har en KEMO Jonisator byggsats för 89:-
    http://195.67.69.169/kocny/infovisa.asp?87137
  • HydraMan
    2003-12-30 at 13:55
    Oj, har de slutat o sälja dem??
    Tja, ingen större förlust, ska man använda jonisator för lukt eller rök så får man se till att den ger ut bamsemängder.
    Skaffa en transformator och löd fast knappnålar på en stam, altså som en gammeldags takantenn för TV. Koppla in 3000-7000V till nålarna.
    Då den elektriska laddningen når nålens ände så puttas de ut i luften. De elektroner som finns bakom nålens spets puttar på.
    Om man känner ca 1-2cm framför nålen så känner man en sk. elektronvind blåsa. Samma som NASA spekulerar kunde användas som drivmotor, högspänning är roligt :D
    2004-01-05 at 17:59
    hydraman du har inte någon trevlig ritning till en jonisator?
    jag har den dära miniminivarianten av kjelles jonisator som ja köpte för väldigt längesen.
    skulle vara trevligt om man hitta en sådan ritning så man kunde göra en stor grej å koppla in i vägguttaget. helst med lite mätvärden så grejjen man bygger inte producerar allt flr mycket ozon.
    dom har på ovanstående länken http://www.innipowerflex.com men man går INTE å köper en sådan…inte för det priset iaf. materialet kostar max 300 spänn skulle jag tro till en stor grej.
  • Thc-Junkie
    2004-01-05 at 18:32
    aka. jondrift eller som på engelska är iondrive 😉
