Moderator: HydraMan
DoD
Gammal & trött
Postby DoD » 2002-06-23 17:26:32
Jag brukar ligga på 4-500 ppm. Ja du skall använda båda. Annars får de ju bara en del av den näring de behöver.
Postby Kadafi » 2002-06-25 23:40:53
det här hittader jag nånstans på OG, jag brukar spara alla bra saker jag läser
Young, established seedlings or rooted cuttings are started at 500-600ppm. The TDS is increased to 800-900ppm during peak vegetative growth. During the transition from early to heavy flowering, TDS is further raised to 1000-1100ppm. It is then reduced to 400-500ppm during the final 2 weeks of flushing. The plants demonstrate their preference for a lower TDS/EC when running a lower pH by clearly sustaining higher growth rates.
