Ett svenskt cannabisforum Forums Coffeeshopen Coffeeshopen Välja Bong? Reply To: Välja Bong?
  • adam
    2009-12-05 at 16:31
    Jag är spekulant på en (prisvärd) “riktig” bong 8)
    Hittade denna: http://www.everyonedoesit.com/online_headshop/Bushmaster_Glass_Water_Bong__Straight_Up.cfm?iProductID=3822 på EDIT för 250kr. Så här skriver de om den:
    “The Bushmaster Glass Water Bong – Super Chunky is one hell of a bong. A beastly 45cm tall, with a much greater smoke volume capacity than most other bongs of a similar height, the Super Chunky also has four ice notches just above the rush (carb) hole so you can fill this monster with as much ice as you need. The Super Chunky is indeed the absolute daddy of the Bushmaster range.
    Glass thickness: 4.0mm
    Weight: 670g
    Size: 45cm tall, 6cm diameter”
    Vad tror ni med mer erfarna bongrökare om den? :D
