Första odlningen / 3 x Easy Ryder (Lowryder xAK47) SKÖRD
kushbringer
Postby kushbringer » 2011-02-24 21:46:32
Tänkte visa lite hur det går för mig o mina damer. Först lite info.
3 st Easy Ryder (Lowryder xAK47)
Secret Jardin Dark Street ll DS60 60x60x140
250W HPS
Kanalfläkt 100mm
Kolfilter
Bordsflläkt
Luftfuktare
Började att locka upp brudarna med lysrör och satte sedan in de i tältet när de hade fått några blad.
Och så här har de gått.
Dag6
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY6/11_01_18_IMG01.jpg[/img][/img]
Dag17
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY17/11_01_29_IMG01.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY17/11_01_29_IMG03.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY17/11_01_29_IMG08.jpg[/img][/img]
Dag22
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY22/11_02_03_IMG01.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY22/11_02_03_IMG04.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY22/11_02_03_IMG07.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY22/11_02_03_IMG11.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY22/11_02_03_IMG12.jpg[/img][/img]
Dag32
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY32/11_02_13_IMG02.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY32/11_02_13_IMG03.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY32/11_02_13_IMG04.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY32/11_02_13_IMG07.jpg[/img][/img]
[img][IMG]http://i1119.photobucket.com/albums/k636/kushbringer/DAY32/11_02_13_IMG08.jpg[/img][/img]
De va de! kommer mer bilder snart :)
Döskallen
Re: Första odlningen / 3 x Easy Ryder (Lowryder xAK47)
Postby Döskallen » 2011-02-24 21:53:14
Vackert! :)
Vad odlar du i för medium?
kushbringer
Postby kushbringer » 2011-02-24 22:01:04
Tack! :)
Kör med Gold Label Special Mix Jord
Har även en tråd ang Näring som jag ska börja med, så har nån någon fundering på denna tråd så skriv gärna.
Döskallen
Postby Döskallen » 2011-02-24 22:17:04
Okej, ang näringen bör du ta de försiktigt.
Samt läsa vad Gold Label Special Mix jorden innehåller!
Har för mig att den är ganska näringsrik, så du inte övergöder den.
kushbringer
Postby kushbringer » 2011-02-24 22:49:03
OK
Tänkte börja försiktigt. De har varit i blom i lite mer än 1 vecka nu och bladen längst ner börjar gulna (kanske näringsbrist) jag har kört i samma kruka från start.
Så jag tänkte köra Vatten / Vatten / Terra Flores (5ml/liter)
Finns det några självklara tecken på övergödning?
Eller är det kanske overkill och köra med näring sin första odling?
Vad händer om man inte använder det?
BudWeisser
Postby BudWeisser » 2011-02-24 23:15:16
Tippar på att du jobbar som fotograf? :)
Jävligt snygga bilder måste jag säga.
kushbringer
Postby kushbringer » 2011-02-24 23:28:10
Hahah tack!
Men visst är de lite kul med foto :)
Nomiar
Postby Nomiar » 2011-02-25 1:07:59
Först en fråga, med den setupen.. Varför välja att göra easyryder? Kunde ju gjort något mycket fetare :D
Och sen för att svara på din fråga: Du ser det lätt om du har lite för mycket näring. Det blir näringsbränna på bladen och du kan säkert hitta massvis med bilder på det här på swecan :)
Ta gärna hälften av rekommenderad dos om du vill vara på säkra sidan. Det är vad som brukar rekommenderas för olika närings medel.
kushbringer
Postby kushbringer » 2011-02-25 7:11:35
Hahah tack!
Chronide
Postby Chronide » 2011-02-25 8:42:04
Fan va snyggt! Jag blir helt tagen av bilderna, kan bara tänka mig hur grymma bilder du tar när budsen är helt täckta me trikomer! Don't let me down! :supersmile:
Ser finfint ut med rydern.
lycka till!
- C
kushbringer
Postby kushbringer » 2011-02-25 18:29:58
Nomiar: Eftersom detta va det första projekt så kollade jag efter enkla låga och inte så luktande växer, därför blev det dessa :) Nästa gpng blir då nog någon av varje. Några tips?
Kommer mer bilder imon, dock då på mina gula löv som någon kanske kan svara på varför.
cthullu
Postby cthullu » 2011-02-25 18:57:43
Är det dom allra nedersta hjärtbladen som gulnar eller stora "riktiga" blad?
Är det hjärtbladen så är det helt normalt, dom ska gulna, dom används mest bara precis när den kommit ur fröet.
Tycker de ser väldigt välmående ut på bilderna nu här i tråden :D
kushbringer
Postby kushbringer » 2011-02-25 19:08:30
Mmm det är de allra nedersta som gulnar. Så då kanske det inte är någon fara.
Jag har plockat bort dem, ska man göra de?
cthullu
Postby cthullu » 2011-02-25 19:49:18
Nomiar
Postby Nomiar » 2011-02-25 23:58:17
kushbringer
Postby kushbringer » 2011-02-27 21:05:58
Då kommer en liten update dag 42.
Någon som har någon fundering ang de gula löven, kanske inte är nått att oroa sig för?
cthullu
Postby cthullu » 2011-02-27 21:42:07
Ja det där är ju definitivt mer än bara hjärtbladen...
Ser ju onekligen ut som brister. Samtidigt lite konfunderad över att bladtaggarna i närbilderna på topparna pekar uppåt vilket de brukar göra vid stark gödning.
Edit: Och har det verkligen gått så fort från ingen gulnad alls den 24:e typ??
Men om du inte börjat med näring så är det dags.
edit2: en pH mätning på avrinningsvattnet är nog bra också...
GanjaLars
Postby GanjaLars » 2011-02-28 11:03:45
Tack kushbringer för dessa underbara fotografier! Bra perspektiver. Odlingen ser mycket fin ut. Tror också du kan tillsätta lite näring. Lycka till in future
kushbringer
Postby kushbringer » 2011-03-02 18:34:26
Nu är det så att min risiga lilla luftfuktare har pajat och behöver en ny omgående. Någon som har nått tips? Har kollat in Mist Maker, någon som testat den? Fattar inte riktigt hur man kopplar den till en extern tank.
/Kushbringer
kushbringer
Postby kushbringer » 2011-03-05 14:17:29
Då var vi uppe i dag 52 sedan de sattes i jorden och det är en vacker syn.
Hoppas ni gillar de.
PEACE!
puffovich
Re: Första odlningen / 3 x Easy Ryder (Lowryder xAK47) Dag52
Postby puffovich » 2011-03-05 16:59:35
Ser nice ut! Den strainen borde ju påminna en hel del om Automatic AK47 som jag har erfarenhet av vilken gav mycket trevligt röka :)
Bongomongo
Postby Bongomongo » 2011-03-05 17:46:20
niccce ;)
kushbringer
Postby kushbringer » 2011-03-06 15:41:08
Någon som har någon idé om hur lång tid det kan vara kvar till skörd?
Jag har inte så stor koll på när man ska ta "den" Några generella tips kanske?
puffovich
Postby puffovich » 2011-03-07 16:45:11
Döskallen
Postby Döskallen » 2011-03-07 18:30:18
Fina damer! :)
Jag skulle nog väntat lite till.
Men de mesta beror på vad herrn är ute efter för rus.
Har märkt själv, att när man tar tidigare (50-65% av thrichomerna är röda/brons färgade).
Så får man ett mer uppåt rus, väntar man blir
de ett mer kroppsrus.
Men sen bör man tänka på vad de är för sorts planta också! Finns juh indica, sen sativa
men även blandningar. För är de exempel en indica,
kan man lika gärna vänta tills 80-90%. Detta är enligt min
efarenhet samt de jag läst & sett. Man bör ta allt med en nypa salt! ;)
Men sen är jag för, att man ska experimentera inom sitt odlande.
Så ta någon/några kvistar om någon vecka. För att sedan ta &
upprepa, för att få fram de du just gillar bäst.
Ett annat tips är att läsa olika guider, samt andra bildloggar för info.
Söka på google, efter just din strain kan ge mycket info.
Lycka till! :)
frilansaren
Postby frilansaren » 2011-03-16 8:48:22
Hur står krukor har du?
Må väl
kushbringer
Första odlningen / 3 x Easy Ryder (Lowryder xAK47) Dag64
Postby kushbringer » 2011-03-17 17:44:30
Halo!
Då har vi kommit till dag 64 och snart dags för skörd tror jag. Snackade som för lite mer "uppåt" rus så skulle man ta dem lite tidigare. Är detta tidigt nog eller är jag för ivrig? :)
/Kushbringer
[img][IMG]http://img696.imageshack.us/img696/6778/dsc0009nh.jpg[/img][/img]
[img][IMG]http://img811.imageshack.us/img811/5005/dsc0008zj.jpg[/img][/img]
[img][IMG]http://img231.imageshack.us/img231/7529/dsc0007iu.jpg[/img][/img]
[img][IMG]http://img858.imageshack.us/img858/9282/dsc0006k.jpg[/img][/img]
[img][IMG]http://img59.imageshack.us/img59/9714/dsc0005dx.jpg[/img][/img]
[img][IMG]http://img703.imageshack.us/img703/3166/dsc0004ky.jpg[/img][/img]
[img][IMG]http://img823.imageshack.us/img823/7320/dsc0003do.jpg[/img][/img]
[img][IMG]http://img269.imageshack.us/img269/5749/dsc0002mv.jpg[/img][/img]
[img][IMG]http://img121.imageshack.us/img121/2131/dsc0001ur.jpg[/img][/img]
Toaster57
Re: Första odlningen / 3 x Easy Ryder (Lowryder xAK47) Dag64
Postby Toaster57 » 2011-03-17 17:51:35
Sjukt fina honor och bilder, blir riktigt avis faktiskt! Bra jobbat och hoppas det smakar! :)
Postby Wayne » 2011-03-17 18:00:41
Hur många dagar anger fröbanken att de bör blomma?
Har du tittat på trichomerna i mikroskop?
Skulle vilja se på budsen lite närmre innan jag säger om du kan skörda eller ej... Jag är tycker iaf att man ska välja en "uppåt sort" om man vill ha uppåtrus och inte skörda sina plantor för tidigt.
Fritz
Postby Fritz » 2011-03-17 18:12:41
Väldigt snyggt, kushbringer! Bra jobbat! :D
kushbringer
Postby kushbringer » 2011-03-17 18:19:18
Ska ta och skaffa mig ett litet microscope och se hur det ser ut på nära håll.
På förpackningen säger de Harvest: 10/11 weeks from seed ser jag nu, och om jag räknar rätt så är det start på V9 nu så det är nog minst 1 vecka kvar då kanske?
Kort fråga ang torkning, det ska väl inte vara några konstigheter och torka i tältet med fläktsystemet på för minimal lukt.
Info: Kör i 3 liters krukor
PS. Nate Dogg R.I.P
Postby Wayne » 2011-03-17 18:28:04
Ja, minst en vecka skulle jag tro. Jag ser inte hur många vita pistiller du har på bilderna riktigt men det är alltid bättre att vänta för länge än för lite. Även om det ser ut som det inte händer något så händer det mycket inuti calyxerna, det är på slutet som vikten läggs på...
Din idé om torkningen är en bra idé.
Baronen
Postby Baronen » 2011-03-17 19:13:30
Damn. That is some real sticky icky buds. Har du tjuvnypt något än? :P
Chronide
Postby Chronide » 2011-03-17 21:06:24
Haha, vilka julgranar! Känns som att presenter kommer snart :supersmile:
Awesome work. Sjukt impad. Ska bli kul med vikt/smoke report =)
- C
Grabben
Postby Grabben » 2011-03-17 22:22:38
Mmmm goa bilder du bjuder oss på, riktigt fina damer :)
Torka i odlingsutrymmet går fint, som du säger slipper man lukten + att de är ett bra ställe att torka på :) . Tänk på att inte ha nån fläkt blåsande på budsen eller för låg luftfuktighet. Läs en guide hur man torkar o kurerar så går de som en dans på.. Fint kurerat ganja ? Jaa :D
kushbringer
Postby kushbringer » 2011-03-19 10:11:15
Liten update och några närbilder.
EDIT: Lyckades ta några micro också med mitt lilla nyinköpta microscpoe :)
EDIT2: Samlingsbild på The Sisters
[img][IMG]http://img192.imageshack.us/img192/1374/ladygeen04.jpg[/img][/img]
[img][IMG]http://img846.imageshack.us/img846/8425/ladygeen03.jpg[/img][/img]
[img][IMG]http://img834.imageshack.us/img834/4696/ladygeen02.jpg[/img][/img]
[img][IMG]http://img847.imageshack.us/img847/9465/ladygeen01.jpg[/img][/img]
[img][IMG]http://img696.imageshack.us/img696/536/micro03.jpg[/img][/img]
[img][IMG]http://img638.imageshack.us/img638/5959/micro02.jpg[/img][/img]
[img][IMG]http://img193.imageshack.us/img193/8264/micro01.jpg[/img][/img]
[img][IMG]http://img707.imageshack.us/img707/298/sistersrd.jpg[/img][/img]
cthullu
Postby cthullu » 2011-03-19 10:29:36
tummen upp, fina kristallbilder! :P
edit: skulle gärna se plantorna nu i helfigur också :)
Charlie_Sheen
Re: Första odlningen / 3 x Easy Ryder (Lowryder xAK47) Dag66
Postby Charlie_Sheen » 2011-03-19 13:55:59
Mums var fina dom är!!!
Duh, Winning! I'm not bipolar I'm Bi-winning!!
derex
Postby derex » 2011-03-20 15:19:53
Mmm vad fint. Tänker köra 4 stycken feminiserade easy ryder ute i sommar, blir dom så här feta så kommer jag bli överlycklig :love:
frilansaren
Postby frilansaren » 2011-03-20 15:27:58
detta var kul att se,
ska själv köra denna strain ute, fast satte 1 redan nu inne som även den står i Gold label´s special mix, fast i en 10liters smartpot. :)
må väl
derex
Postby derex » 2011-03-20 15:58:32
Sournois
Postby Sournois » 2011-03-20 16:21:46
Galna buds, väldigt imponerande! Om min lilla easy ryder ens kommer i närheten blir jag överlycklig!
Lycka till med skörden! :D
frilansaren
Postby frilansaren » 2011-03-20 16:23:03
ja precis,,
jag tänkte även ställa ut lite Grass-O-Matic Mass , ska bli spännande :)
kushbringer
Postby kushbringer » 2011-03-27 17:11:55
Då va de klippt o klart och såhär blev de.
Några tankar? Vad tror ni om vikt på detta?
Va de ok för 3 plantor och för min första odling?
[img][IMG]http://img834.imageshack.us/img834/8358/trim02.jpg[/img][/img]
[img][IMG]http://img109.imageshack.us/img109/8366/trim01.jpg[/img][/img]
derex
Re: Första odlningen / 3 x Easy Ryder (Lowryder xAK47) SKÖRD
Postby derex » 2011-03-27 18:30:30
Ok? Det var bättre än ok, imponerande!!
Crazy_K
Postby Crazy_K » 2011-03-27 18:33:18
Det ser väl la inte så pjåkigt ut för å vara första gången, men va vet jag. :D
Quizer
Postby Quizer » 2011-03-27 19:45:28
fyfan vad vackra dom är hoppas det smakar :O
Empa
Postby Empa » 2011-03-28 19:43:11
Ser sjukt vackert ut :D Har du vägt budsen?
Chronide
Postby Chronide » 2011-03-28 20:24:34
Härligt! Viktrapport och smokerapport som vanligt ! :D
Grattis!
EDIT: Hur tog du bilderna på kristallerna? Hur stor förstornig är det? Riktigt fina bilder!
- C
kushbringer
Postby kushbringer » 2011-03-28 20:36:27
Yo!
Har inte vägt budsen, hade ingen våg för tillfället men kommer göra de när
det är torkat o klart.
Bilderna är tagna med en systemkamera igenom ett microskop som jag köpte på classe O.
/kushbringer
